If you want a shift light in a sub 200 horsepower beater daily you are a special caliber of person. In the worst possible way.
All the same the wire to tap is the white wire on the distributor. It carries the ignition check signal to the ECU and can be piggybacked for a tach/light or whatever ricetacular retardation you can dream up.
