Thread: Chrisblack build
Showing results 41 to 60 of 84
  1. #41
    I gotcha
    daliy galant es 5 speed in the making
  2. #42
    You shouldn't have to use a relay, just disconnect the power from the stock horn and connect it to the new ones dont forget to ground them and they'll work.
    Remember the stock horn is already run by a relay, no need to add another.
  3. #43
    some pics from weakest 2k14 in maimi florida
  4. #44
    Cleaned up this thread a bit... chrisblack, if you're going to post a series of pictures, please make only one post. You should be able to post multiple pictures at once; no need to create a separate post for each picture. Thanks!
  5. #45
    Sorry man I didn't know.....
  6. #46
    Can someone chime un on this I bought lowering spring 2in drop will these need a fender roll( I think It will just wanna double check, it's 18 inch rim it comes with all four rims and tires for 500$
  7. #47
    Keep in mind the springs are not in yet there in the mail
  8. #48
    Tire size? Probably gonna be fine either way but tire size is important...and rim offset
  9. #49
    I'll give it a check tommorow can't remember the tire size
  10. #50
    Theres a slim chance you wont need a fender roll after the drop.
    If you like the wheels dont let something so simple as a fender roll prevent you from getting them.
  11. #51
    my springs came in now waiting on other parts to roll in the mail
  12. #52
    when putting in the new struts and springs, do I only need to support to control arm....wanna make sure before I start
  13. #53
    TGC Lifetime Patron Palmz's Avatar
    04-14-2011
    Iceland
    533
    plz post a video of ure car being towed :D other than that nice ride
    dont know about the control arm
    2001 Galant 2.4 USDM
    Old ones
    2X BMW E34 Blaaackkkk
    Isuzu Trooper mountain spec
  14. #54
    I might tear off my bumper lol...but alright thanks
  15. #55
    07-02-2011
    South Florida, by the beach
    1,076
    Quote Originally Posted by chrisblack View Post
    this is what I did:
    01 Galant ES V6 MT (sold)
    00 Eclipse RS MT
  16. #56
    Thanks man, this will help a lot
  17. #57
    I finally got around to putting in the springs
  18. #58
    Points for trying. Really though. The only image that tells me anything is the one with both springs side by side, had I not seen that I wouldn't know what happened.
    You have an image of a fenderwell with no strut, should have took the picture after the strut with new spring was on. Then theres the picture of a steelie with a gap, don't know whether its before or after. And then you have 2 shots with uneven grass, creating an illusion, but I still don't know if the illusion is a lowered car or not. Like I said points for trying. But perhaps a full body side shot on even pavement would be good. Then get an old picture to show the before/after.
    Idk maybe im on one because I didn't get my coffee this morning.
  19. #59
    04-14-2011
    Iceland
    533
    ^^ that
    Old ones
  20. #60
    Ok
