Thread: Car shutting off on reverse
Showing results 1 to 3 of 3
    Ok so I am still new to this site but anyways my car shut off on reverse when backing out (1996 galant, automatic) just got a new used transmission with 120k miles. So when I back out or take to long to back out the car starts to shake and shuts off. Any ideas on what the problem is?
    TGC Lifetime Patron Solviss's Avatar
    12-04-2013
    Jacksonville, Florida
    260
    Last place to look is the ecu. I had a capacitor that went bad and caused the car to die in situations like this
    Typically there is a vacuum leak that will cause the car to stall or shut off when reversing. You should be able to hear a vacuum leak from underhood. You may need to have someone else cycle through the gears while you listen for a vacuum leak. Either way you should have a vacuum diagram underhood to trace the vacuum lines to see if there are any damaged lines. If so, simply replace them and move to the next step.
