Thread: HomeMade Galants Build Thread!!!
Page 11 of 19 FirstFirst ... 789101112131415 ... LastLast
Showing results 201 to 220 of 361
  1. #201
    TGC Regular boosting90's Avatar
    05-14-2014
    Central Florida
    426
    Installed oil feed fitting.
    Workin on makin a tilt flange for evo manifold. Will post pictures once is fitted and know tht works. Then will finish welding and then coating. As of now is just tacked
    Sent from my SM-N920T using Tapatalk
  2. #202
    What did u use that step bit for??
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  3. #203
    05-14-2014
    Central Florida
    426
    For the crush copper washers. And same size bit for bandrel fitting.
  4. #204
    Banjo* fitting. Make sure there are no burrs on those washers to insure proper seal.
    '95 Kawasaki ZX9R
  5. #205
    05-14-2014
    Central Florida
    426
    Will do. And yes banjo lol
  6. #206
    05-14-2014
    Central Florida
    426
    Test fit flange and fits. Tight but fits. Will finish weld this week at work.
    Did some wiring done. Did the timing area wires. (Crank,p/s,ac) and wipers plugs was re route same.
  7. #207
    05-14-2014
    Central Florida
    426
    Angle flange is all welded. Next few days with grind smooth. And ceramic coated.
    #HomeMade
  8. #208
    Hopefully that flange didn't warp from the heat and will seal properly.
    '95 Kawasaki ZX9R
  9. #209
    that's easy to mill
  10. #210
    05-14-2014
    Central Florida
    426
    Test fitted against head bolted. No wrap.
  11. #211
    05-14-2014
    Central Florida
    426
    Did some more wiring. Injectors section. Mock them. Still need to wire into harness. But u get the idea.
  12. #212
    What's the resistor for
    '95 Kawasaki ZX9R
  13. #213
    05-14-2014
    Central Florida
    426
    Injectors. Evo8 560cc. Instead of have a used or faulty big box in the bay. I use this resistors for a cleaner and knowing is new. My piece of mind.
    (Remember when i ask if dsm and evo are same resistance) i have used this many times for low impendace injectors.
  14. #214
    Quote Originally Posted by boosting90 View Post
    I like to keep it as Oem as possible. The Oem resistor boxes aren't known to have any issues. But that's just me.
    '95 Kawasaki ZX9R
  15. #215
    05-14-2014
    Central Florida
    426
    I like the idea and never had an issue with these.
  16. #216
    any luck with that manifold spacer? ive got a couple of those flanges laying around as well and was thinking of doing the same thing.
  17. #217
    05-14-2014
    Central Florida
    426
    Yes i mount it and cleared. I have to do some sanding and coating once is all done i will take better pictures.
  18. #218
    05-14-2014
    Central Florida
    426
    Been super busy. My cars decided to break all at the same time. So now all done and working good. Time to get this out of here, tired of lookin at it. If is just 10 mins a day, i will get this car done. Clean and did some organizing.
  19. #219
    05-14-2014
    Central Florida
    426
    Full wired coils and injectors.
  20. #220
    05-14-2014
    Central Florida
    426
    Cam and coolant sensor wired
