Personally I dont think you can make a AWD be FWD, even if it bolts up.
But ill let the people with more knowledge chime in.
You may be better off doing a full awd swap if possible.
Hello guy's i'm new to the forum, U have EU Galant 8 2.5V6 tiptronic gearbox, its a 4spd auto, i got a 5spd auto from VR4 but its AWD, is there a way to make it FWD only and use it in my car, the engines are 6A13 and the bellhousing is the same for the 2 cars, i think i'll need the transmission ECU as well. I've searched the internet but didn't find a photo example of someone doing this. The reason i'm doing this is simple VR4 5spd auto has better gears and car will have better mileage, and acceleration with it :)
i could just be talking but i heard somewhere you could just plug up the rwd portion of the awd system to make it run as if the rear wheels were not active
Its easy yes but u gotta know how to weld and a new tank is also needed. Doin this atm
2001 Galant 2.4 USDMOld ones
2X BMW E34 Blaaackkkk
Isuzu Trooper mountain spec
If u really want to make it fwd u can weld up the transfer case and close the hole for the rrar drive shaft... but its a waist of a good transmission imo
