Member
MFI relay buzzing
Hello,
I am still trying to diagnose a charging issue.
No light on the gauge cluster for the battery when the key is inserted into the ignition but not cranked. I noticed today that when I start the car there is a buzzing from the MFI relay.
Alternator tested good twice. Checked all the fuses and grounds. Replaced the 120 and 60 amp fuses anyway.
Any help would be appreciated.
Not sure about the voltage drop test and if I did it correctly.
Thanks
