Thread: Choosing tires
Showing results 1 to 17 of 17
    Choosing tires
    Ok so I lower my 8g about two inches and I got some 17×8 rims what would be a good tire size
    215/45/17 whether its lowered or not.
    you want something that is close to the stock overall diameter of the wheel/tire you're replacing. that way your speedometer wont be off. 225/45/17 will be cheaper to get and shouldn't rub if your offset is correct. 215 might be the correct way to go, but you will spend more since tire places think that is a special width for some odd reason.
    I had 225/45/17 on my BBS.
    No issues at all.
    Quote Originally Posted by birchette42 View Post
    Why wouldn't 225-45-17 be good
    Didn't say that wouldn't be good. I simply mentioned the most correct size as far as overall height goes.
    For a 17x8 +40mm wheel setup, either tire size should work. However, with 225/45R17s due to the addition tread width it is more likely with 2" of lowering you will rub slightly on the rear quarter panels. As always, when lowering these vehicles it is highly recommended to 1) Test fit your desired combination and 2) roll the rear quarter panels if your vehicle is lowered.
    Put it it this way, im lowered about 2in. With coils on evo 9 wheels wrapped in 225/45/17, and if it wasn't for the fender job in back they would be rubbing.
    Evo 9's are 17x8 +35
    Theres nothing wrong with 225/45. If you want them run them, it may be a better fit since the 215's will have a little stretch.
    Too small.
    Ok thank so with the 225/45-17 will they fill the front wheel well or would I have a lil gap
    You never change tire sizes to eliminate wheel well gaps, you do so by lowering the car.
    My 225/45/17 Michelin Pilot Sports did not rub with my 17x8 +40 setup.
    Fenders were untouched, wheel liners untouched, etc.
    Lowered on Tein S-Techs.
    I'm amazed I remember ANY of that.
    Michelins tend to run small, so that isn't a surprise.
    Im running 245-40 with a 35 offset, same size wheel
