Thread: need help on my guages
Showing results 1 to 3 of 3
    They seemed to all work except the rpm... is the whole rpm need to be replace or is there a way to fix this problem
    Thanks
    10-24-2003
    1,432
    It depends if there is a fault in the tachometer itself or the wiring too the tachometer. I'd be willing to bet its the wiring too it.
    www.gooichimotorsports.com
