Small search would have uncovered this valuable thread
https://www.thegalantcenter.org/showthread.php?t=49684
I was wondering if should flush my tranny or just drain the fluid from the pan and replace with new fluid. I know with some tranny flushes it would ruin the tranny because of little pieces of build up could block up some passages causing the tranny to stop working. I haven't changed fluid in awhile because I wasn't sure what I should do. Btw I believe I have the tranny with the filter inside the tranny
Thanx for the thread now im gonna get a quote from a dealer. Thanx again
I've heard that complete flush can be a bad idea. If your car has been serviced by a dealer regularly, then I think drain and refill method won't hurt your transmission.
