need current info
ok guys i really appreciate all the info/help thanks in advance.
i have timeless hrs doin search and reading and studying.
but either some "thinks" or "hear/saw"
4g64 plus sonata head.
94 galant dohc timing belt allows mw to TDC 0degress (exactly to timing marks)?
if so, ^^^ can i use stock evo8 cam gears?
is there anything the i need to do for head to line up directly with block? (oil/coolant passages)
where can i find 8g to evo8 ecu write up? or pin outs of each ecu?
thanks alot again just stuff i really havent found or learned.
