Thread: Door Seneor
Showing results 1 to 2 of 2
    New Member
    10-13-2011
    Springfield, IL
    73
    Door Seneor
    Ok because it is so cold in the Chicago area it is playing games on my Galant. For some odd reason my door sensor will start coming on and the lights come on. If I give the door a little tug then sensor goes off. Has anyone else had this same issue and if so what is the best way to fix it?
    New Member
    04-14-2015
    Edmonton, AB Canada
    55
    Have you checked to see if your door pins are all good? Thats where I would start. If it isn't making full contact it would trigger the dome light and door lights to come on
