Thread: Power Steering Only works at high rpm
Showing results 1 to 3 of 3
    I have replaced the power steering pump bleed the system and still only works at high rpm. Any ideas on what the problem may be?
    It is possible there is a block in one of the lines, or one of the lines is allowing air in to the system.
    Try re-bleeding the power steering system, also as always, inspect any lines for breaks or leaks.
    Does it only give you power steering under acceleration?
