Thread: Power Steering Only works at high rpm
Showing results 1 to 2 of 2
    I have replaced the power steering pump bleed the system and still only works at high rpm. Any ideas on what the problem may be?
    could be a clogged line. howd the fluid look when you changed the pump?
