Axis good fitment?
Hello Children, I am planning on Axis wheels, the Super wheels mesh or the Spyder, but I need ot make sure if they will actually fit.. they will be
Super mesh: 19 x 8.5"
5 LUG ONLY= 5x100, 5x112, 5x114.3, 5x120
35, 40, 45 MM offset
2.5" lip
Spyder: 19 x 8"
5 LUG - 5x100/114.3 5x112/5x120
35, 45mm Offset
2" lip
thanks guys
kinda wide 8 and 8.5... bolt pattern 5x114.3, whats the offset on the wheels?
::edit::
where in central nj r u? im in freehold township
I'm in Keyport area about 15min from u, are u near the mall??
i might have seen u driving in the downtown area right by Tronix and Freehold Boro HS unless there's another G with black rims
19x8 with a +45mm offset and a 5x114.3 bolt pattern should fit.
19x8.5 with a +45mm offset and a 5x114.3 bolt pattern is cutting it kind of close. The 8.5" width might rub on the suspension unless you go with the +40mm offset, but then you will probably have fender rubbing in the rear.
You'll want to go with a 225/35 tire.
