Thread: Need help for my 6a12 NA 2.0 upgrade
Showing results 1 to 2 of 2
    Greetings galant'ers..😅
    A few weeks ago i just i got involved in excident 😢😢 it make my car dont get smooth like before..
    So now my car are already fixed..
    Yeaaayy..
    So now im just feel like i need some upgrade for the engine..
    1st thing..i dont like a turbo ( i dont need big HP)
    Here some list that i want to do:-
    1. Change transmission from auto to manual (i just get one and just wait..under construction)
    2. What type of hi Cam & cam pully that i can use.
    3. Piping exaust.
    4. Racing clucth.
    5. Piston?
    I need some advise for more engine improvement..maybe change the big piston 😂
    6a12 non turbo have very weak manual transmissions. The differential likes to go bye bye on them.
    The only way to make power is with turbo. You can do a single turbo with whatever is available in your country - garretts or whatever. You can make decent power on 8-10 psi of pressure. You can buy a MAFT online, I'd suggest MAFT gen 2. Its a bit more expensive, but its well worth it. You can also tune it with SAFC which is less expensive. I've run upto 15psi on a big turbo and stock ECU with SAFC
    Exhaust from 2g eclipse fits with some extending and I wouldnt go bigger than 2.5 inches.
    Cold air intakes and other mods dont really work.
