Thread: 98 2.4..got hot, replaced melted wire set and plugs, wont start
Showing results 1 to 3 of 3
    98GALANTMOBILE
    coming home one night just did timing belt set, broke a water hose, got a little hot. i replaced wire set, plugs. i spray ether and it tries to start. i have fuel to rail, injectors test good at 15 ohms. no spray. tested crank sensor solid signal of 6 volts. code reader worked before, if i wiggle it tries to work. any idea;s? 230000 miles good compression, no water in oil, the fuel throttle body hose broke. i also replaced mfi/efi dual relay pack, can hear run. i am thnking crank sensor????
    08-13-2008
    Waterbury, CT
    3,331
    Check fuses
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
    98GALANTMOBILE
    fuses good. installed new efi/fuel pump relay. the fuel pump did not come on. ran seperate ground wire at fuel pump under seat, fuel pump came on. injectors not spraying. help.
