Thread: how to check fuel pressure on this damn car
Showing results 1 to 3 of 3
    New Member BLOCK8732's Avatar
    10-08-2012
    Tappahannock Va,
    75
    How do I check the fuel pressure on my 2.4l. There is no port to hook up to so what do I need to tap into fuel line to check pressure. What should the pressure be once I get a way to check it
    05-14-2010
    Coachella, CA
    5,954
    Where the feed disconnecs from the hard line at the firewall.
    10-08-2012
    Tappahannock Va,
    75
    Ok thanx alot
Tags for this Thread
