Thread: $350 4g64 5 speed swap project started
Page 9 of 14 FirstFirst ... 5678910111213 ... LastLast
Showing results 161 to 180 of 264
  1. #161
    Quote Originally Posted by white2k3mitsu View Post
    I went to the junkyard and pulled a 3g tranny with clutch lines, clutch and break pedals, master / slave cylinder, hard and soft lines, 3 harness pigtails, shifter assembly, flywheel, pressure plate, clutch and clutch fluid reservoir and sonata dohc for 146 and basically other then the dohc (lol) am I missing anything in my parts list for the swap I've done my research and see some posts about maybe using a 3g or evo ecu but I'm not sure if I need it I have a 03 2.4 es also what wiring needs to be done and how hard is it I must admit this is my first time doing anything like this but I was able to take these parts off so I'm pretty sure I can put them back on
    I swapped engines too so I needed a lot more parts. I believe there are multiple threads in the swap...
    But as far as I can remember, you'll need the following parts:
    -manual transmission
    -clutch
    -pressure plate
    -flywheel
    -clutch pedal assembly
    -clutch master cylinder
    -clutch fluid reservoir
    -clutch fluid lines
    -shifter assembly
    -shifter cables
    -throw out bearing
    That's everything I can think of. I believe you have to jump the neutral safety switch. No you don't need an eclipse ecu. I'm not sure about the clutch pedal sensors and wiring them in. I had to make my own harnesses
    Sent from my SM-G925T using Tapatalk
  2. #162
    Sudden change of plans. The rear sub frame will now be getting replaced before my suspension is complete
  3. #163
    Some quick updates...
  4. #164
    08-26-2007
    L.I.N.Y./ Rockville MD
    1,148
    Nice progress!
  5. #165
    Paint the area where u exposed bare metal or else it will rust very quickly.
    Sent from my LG-H830 using Tapatalk
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
  6. #166
    Yeah I'll spray it next time it's in the air
  7. #167
    Couple updates from today...
    Secured my battery in the trunk
    Made a brake bleeder adapter to flush the brakes more easily
  8. #168
    Quote Originally Posted by amaru7 View Post
    What's this homemade bleeder for exactly?
    '95 Kawasaki ZX9R
  9. #169
    It's a spare brake fluid reservoir cap that I have. It goes onto the reservoir and then a hose from the brake bleeder machine connects to the fitting. The brake bleeder applies pressure to the system so you just open each bleeder screw and fluid comes out. No need to have someone pumping the pedal anymore. Obviously you must use a spare cap because you can't leave the system open because brake fluid is hygroscopic. Normally I use the brake bleeder at a pressure of 2 bar, but our caps are weaker than the typical cap I use, so I'll apply only about .5 bar.
  10. #170
    Makes sense. I just gravity bleed and works well for me. I did it on both cars with brembos and had no problems. Nifty tool though.
    '95 Kawasaki ZX9R
  11. #171
    I'll post a picture of it hooked up. It's what we use in the dealership
  12. #172
    My hood needs to be replaced. It's rusted and bent. It looked insanely bad with the clear coat bubbling up all over it, so I did a quick touch up
    I ground all the paint and bondo off:
    Quick hand sanding:
    Couple coats:
  13. #173
    One ended up not being enough, so I had to install 2 on each side, but here's a picture of one front camber bolt
  14. #174
    08-26-2007
    1,148
    Camber plates might helpful. You can max those bolts all the way negative then use the camber plates to fine tune the camber and will be much easier then having to keep taking the wheel on and off for adjustments.
  15. #175
    Quote Originally Posted by xd_01 View Post
    Luckily I can adjust them with the wheels on while it's on the alignment rack. But yes, camber plates are a good idea. Any idea who makes them for our cars?
  16. #176
    08-26-2007
    1,148
    Thats a good thing! I havent really searched for galant specific ones, although evo ones look dead on. I havent tested my theory yet since i have plates on my coilovers but there is a used set ive been looking at being sold on evom that not only adjust camber but also caster.
  17. #177
    Interesting. I'll look into it, but my front camber is just barely out of spec now. Wouldn't the plate actually lift my car about 1/2"? I'm honestly not exactly sure how those plates install.
  18. #178
    08-26-2007
    1,148
    Thats tru but probaly not by a 1/2". That would really depend on the plate thickness and the spherical ball used. Typically these are used on coilovers so if there is a difference in height it can be adjusted. I know you dont have coilovers so it probably wasnt a good idea to suggest them.
    They basically replace the top hat, that easy. They rest on the same step on the piston shaft as oem.
  19. #179
    It's worth looking into at least. Especially if it's camber and caster. I'll be on coilovers eventually
  20. #180
    08-26-2007
    1,148
    Maybe so but most coilovers come with camber plates anyhow so waiting might be a cheaper option. Ive never seen any 8g coilovers come with a combo caster/camber plate but if that interest you the brand plates I saw for sale on Evom where K-Mac. Like I mention before Ive never personally tried Evo plates but they look dead on.
