Thread: Springs and Struts. Then what?
Showing results 1 to 3 of 3
    I have GR2 / Tein S struts and springs coming in soon for my 03 V6. My question is, what else might I expect to run into after swapping them out. I've heard I might have to replace sway bar links, axles, bump stops, possibly get a camber kit, all sorts of stuff.
    What did yall run into?
    GaB
    Experienced TGC Member njjfudge's Avatar
    02-28-2005
    Jonesboro, GA
    1,447
    trim bump stops down some and get a camber kit, everything else should be fine
    2001 w/Old Style VR-4 front conversion
    How drastic a kit do I need, new bolts or a whole new setup? Any recommendations?
    GaB
