Thread: Weird wiring issue.
Showing results 1 to 2 of 2
    Weird wiring issue.
    Ok so to start i f-ed up my car and dont know how to fix it. I was trying to do the mod where the fog lights come on with the parking lights. It didnt work and when i put the relay back in it doesnt work. I switched the relay and it still doesnt work. I also removed another relay to test and now it doesnt work. Anytime i remove a relay whatever it goes to stops working. I have replaced the relays and still nothing. If i take the relay out and jump it the lights will come on.
    2001 Galant
    Aftermarket alarm with remote start
    Sound system
    Second battery and capacitor.
    Led underglow kit.
    3.0 automatic. Es
    is everything back to stock? rip all wiring out and start from scratch. make sure you have power and ground where youre supposed to. did you send power or ground up the wrong wire and could it have gone up to your fuse and popped it? keep it simple, wiring is like a road map, if you have power at certain places you can rule out what circuit is good and point you in a better direction. haynes has a good wiring section for the 8g if that helps at all.
