Thread: Tow hooks?
Showing results 1 to 2 of 2
    New Member
    04-14-2015
    Edmonton, AB Canada
    55
    Tow hooks?
    Anyone know of a good spot to hook up to on the 9G if you have to pull the car out or pull someone else out?
    Or what would be a good spot to add a hook?
    My rear hook is welded to the chassis. I assume the front will handle the same way as well.
Tags for this Thread
