Thread: Timing belt change on 2009 Galant
Showing results 1 to 2 of 2
    Hello Everyone,
    I will be changing timing belt on my 2009 Galant soon, when it reaches 105,000 miles (around in 2-4 months), currently at 98,000.
    I went to dealer and he said that I don't need to change everything, just belt and water pump will do. And depending on parts he use it will cost anything between 700-1000 USD. I was thinking he will be using oem parts till he said depending on quality of parts. So I visited a local garage who will do it for labor, I might ask him to order parts as well and pay a little extra for liability.
    I had look at gates timing belt kit with water pump (TCKWP340) but due to bad reviews of water pump on it I decided to get parts separately.
    This is the list of parts I am thinking of buying.
    Gates TCK340
    2 x timing belts
    1 x idler
    2 x tensioner
    AISIN BTM001
    1 x cam. tensioner hyd. assy
    GMB 1481780
    1 x water pump
    1 x gasket
    Seal kit
    1 x cam seals
    1 x crankshaft seals
    IKH20TT
    4 x spark plugs
    1 x thermostat OEM
    1 x timing cover gasket/seal
    only if needed, since it is making some noise
    1 x gates serpentine belt + pulley + tensioner
    Let me know your opinion on brands, parts I should be changing, parts I don't need to change etc
    Also, If anyone from Rochester NY area, can suggest me a good shop to do these.
    Use oem parts only when doing timing belt job. Don't fuck with aftermarket especially the belt.
    2007 Galant GTS? 2.4L
