Thread: Ticking after timing belt change?
Showing results 1 to 3 of 3
    Hey guys, just got done changing timing belt, pulleys, tensioner, and water pump. On start up, it fired right up and idles perfect. But, I have loud tapping from valve covers. I have read that this is normal for a while.
    Has anyone had this on the 3.8L? I don't want to tear back apart, unless I have to.
    Sent from my VS985 4G using Tapatalk
    Tapping did go away after driving. I found that when you crank engine by hand, when setting belt, that no oil is pumped. So lifters loose oil. Takes a little while for it to build back up.
