Thread: Tuning issues with a/c on.
Showing results 1 to 4 of 4
    NOyPz
    I had this different IAC installed so as to raise the rpm when a/c is kicking. Problem is that the engine still feels like heavy when the a/c is running. No matter what tuning I did (BISS, turning the distributor), the result is still the same. My A/C is not overcharged by the way. What should I do? Get a new Throttle Body with the IAC? I'm on a tight budget so that would be the last option. Please advise. Thank you in advance
    the engine will feel heavy due to the extra load when the a/c is on. nothing u do will change that.
    '91 Kawasaki ZX7 (SOLD)
    '95 Kawasaki ZX9R
    NOyPz
    Yup I agree. Maybe I'm just comparing it with another. I rode a 1997 Toyota Camry 2.2 automatic trans and the feel is different. When I stepped on the gas pedal, it feels lighter even with a/c on.. Considering that my 7g has a customized headers. Maybe I just want to know if it is normal on 7g galant or that mine has a problem.
    It's normal.
    Sent from my LG-H830 using Tapatalk
    '95 Kawasaki ZX9R
