Thread: alternator bearings part numbers
Showing results 1 to 1 of 1
    Anyone know part numbers for the bearings from Napa? 2002 Galant 2.4. I found the rear bearing on OEM parts but trying to find local bearings. Thanks.
    I couldnt find none locally however there is a small town on over and they have a small starter/alternator shop. I called them and they said they would rebuild the alternator, put in new bearings and brushes all for $35 up to $45 including parts. Seems pretty good to me because a Alternator from AAP is about $230 with tax. Only thing wrong with mine is the bearing is starting to make noise.
