Thread: 09 galant 2.4l
Showing results 1 to 4 of 4
    09 galant 2.4l
    I installed a cai and I feel like it's not getting the throttle response ots.supposed to.any suggestions
    07-02-2011
    South Florida, by the beach
    1,076
    The CAI wont give you better throttle response. Cleaning the Throttle Body (TB) will help with better throttle response. The 8G has a throttle cable, I'm assuming the 9G does, you can check the throttle cable attached to the TB, you can take the slack out if there is any and tighten it up. Don't pull it too tight where the throttle plate is open and you can audibly here the RPMs increase, then you went too far.
    01 Galant ES V6 MT (sold)
    00 Eclipse RS MT
    Did clean the throttle body and it still feels like no power til I hit 4K
    Stock or lightly modified engine won't make any power until you hit 4k. Torque peak comes up around 4500, IIRC. Intake manifold and throttle body upgrades mainly help with power at the top of the rev range.
    2000 Mitsubishi Galant (totalled by semi, RIP)
    2000 Mitsubishi Galant - Bought off Craigslist, received organ donation from last one:
    - Engine/5spd trans/interior/suspension/brakes/etc. all moved from old car
    - 5spd | Outlander IM | StopTech BBK | Defi VSD-X HUD
