Thread: Galant Shifting Very Late At High RPMs
Showing results 1 to 7 of 7
    My Mitsubishi Galant 2000 ES 2.4L 4G64 is shifting crazy. Every gear won't shift up until 4,000 RPMs. Sounds like I'm just redlining it the whole time I'm driving. Acts like it wants to get stuck in gear sometimes. Transmission fluid is a little dirty and barely low. Also all of a sudden likes to jerk when shifting instead of smoothly transitioning . Any body have any idea what this could be ??
    Is your check engine light on?
    Sent from my Z981 using Tapatalk
    Quote Originally Posted by BigRedtheGinger View Post
    Yes but it's just a false code triggered by the O2 sensors being cut
    07-02-2011
    South Florida, by the beach
    1,076
    5 speed swap time, muhahahaha
    01 Galant ES V6 MT (sold)
    00 Eclipse RS MT
    This is out of the FSM. Most likely issues might be your output speed sensor or throttle position sensor.
    I can't drive a manual lmao
    - - - Updated - - -
    Thanks @BigRedTheGinger I appreciate it this helps a lot and narrows down my problem.
    You're welcome. If you want, I can post the other pages that follow the one I posted.
