Thread: 4G93 throttling problem
Showing results 1 to 3 of 3
    My 4g93 1.8 engine continue accelerating for more than 30seconds after I stop throttling mostly while on motion, I just replace the engine. Please what could be wrong.
    Sent from my Infinix HOT 4 using Tapatalk
    08-26-2007
    L.I.N.Y./ Rockville MD
    1,148
    Throttle cable sticking? Check tension, also check the linkage on the t/b. Does spring back quickly when you move it manually. If nothing worked i would replace the t/b with the the old one just for the hell of it to see if that works. Im not familiar with gdi's so i hope this helps.
    Thanks it's position settings of the throttle sensor
