Thread: rear disc conversion questions.
Showing results 1 to 4 of 4
    so i've looked over the site, and have gotten plenty of info on how to do the basic, stock to stock rear disc conversion.
    But, what i'm interested in finding out, is, would/is there a way to convert the rear drums to disc, with a set of Front rotors and calipers?
    You cannot (without heavy modification), they are completely different sizes, so the back plates shouldn't fit either. Also, the propotioning valve won't balance the braking the way it is doing now. I have seen the brake hoses are very different as well.
    Thanks for the info! you saved me mad much time and trouble.
    Converting the rears to discs is always a good idea, however if you want to upgrade brakes, the fronts are a priority. They handle most of the braking, so they need to be the better ones. There are tons of options out there, so pick one that works for you. They've all been explored here.
    The fleet:
    88 Volvo 245 DL
    91 Mitsubishi 3000GT SL
    98 Volvo V70
    01 Kia Sportage 4x4
    Check my website JYN
