Thread: Transmission Temp P0710
Showing results 1 to 2 of 2
    Searched the forums didn't find a definite solution to this particular issue, just wondering if anyone has encountered the same problem, and have found a solution
    Thanks in advance
    Note: sensor A transmission temp circuit of that helps any
