Thread: Motor swap transmission problems
Showing results 1 to 20 of 25
    Icon8 Motor swap transmission problems
    Bought an 8g Galant did a motor swap on it and now the transmission won't go into gear can anyone help did something come lose or do I need a rebuild
    Experienced TGC Member AVERAGE's Avatar
    02-09-2006
    Raleigh,NC USA
    1,085
    Did you hook your shift linkage back up?
    Sent from my SM-J700P using Tapatalk
    Yes I hooked everything back up the shiftlinkage is working it's just not engaging in any gear I can push the car while in drive park reverse
    Put it in drive and rev it to about 4k on a flat surface and see if it grabs a little. It's probably a done transmission. V6 or 4 banger?
    The fleet:
    88 Volvo 245 DL
    91 Mitsubishi 3000GT SL
    98 Volvo V70
    01 Kia Sportage 4x4
    Check my website JYN
    It's a 4 banger so either way I look at this pretty much I need to rebuild it or get a whole new 1
    Sent from my Z981 using Tapatalk
    Hey, dumb question but is there fluid in it? No fluid = no solenoid function, therefore no shifting.
    Although I am likely to agree with you, time for a five speed swap! ;)
    The fleet:
    88 Volvo 245 DL
    98 Volvo V70
    01 Kia Sportage 4x4
    Yeah there is fluid in it
    When are you checking it? Because if there's not enough it won't work.
    You should check the fluid when the car is at operating temperature in gear.
    Did you remove the transmission as well as the engine​? Or just replace the transmission? Any other symptoms?
    The fleet:
    88 Volvo 245 DL
    98 Volvo V70
    01 Kia Sportage 4x4
    Yeah the car was on when checking it...And yes when I dropped the motor the transmission came with it
    02-09-2006
    Raleigh,NC USA
    1,085
    Sounds like my situation. Make sure you didn't cross the return lines
    Check that, for sure. Either way, put a manual in it!
    The fleet:
    88 Volvo 245 DL
    98 Volvo V70
    01 Kia Sportage 4x4
    Alright will do didn't even think of that thanks for that and why should I swap it for a 5 speed
    Better driving experience, more reliable, better economy, more​ fun to drive, faster, I can go on and on. Lol
    The fleet:
    88 Volvo 245 DL
    98 Volvo V70
    01 Kia Sportage 4x4
    Yeah I hear you but right now cant afford that looking for the cheapest fix possible right now
    Figured the problem out when the motor got re attached they sucked it together with the bolts and broke the transmission oil pump
    02-09-2006
    Raleigh,NC USA
    1,085
    Where is that?
    What u mean right behind the torque converter
    doh, ive ALMOST done that many times. just gotta have the right feel. the torque converter and oil pump go together with a single slotted gear (similar to a distributor). if the torque converter falls out of that and you dont put it back in correctly then the torque converter will be about a quarter of an inch further out and if you suck the trans in with the bell housing bolts it will crack the oil pump. hopefully they wont make that mistake again!
    Question are Galant and eclipse transmissions interchangable
    Yes
    The fleet:
    88 Volvo 245 DL
    98 Volvo V70
    01 Kia Sportage 4x4
