Thread: Passenger door speakers problem
Showing results 1 to 3 of 3
    New Member
    02-14-2017
    pottsgrove pa
    77
    My passenger door speakers go in and out randomly while you drive and when the car is sitting. The speakers are good and I believe the harness in this door was replaced. I checked for cut wires in the door and don’t know what else to look for or possibly replace any help is appreciated thank you.
    Quote Originally Posted by justin13 View Post
    Was it replaced with a factory harness? Not a lot of other things it to it: did you check the amp or headunit?
    New Member
    02-14-2017
    pottsgrove pa
    77
    I am not sure if it is a factory harness the wires for the speakers don’t have the foam padding like the driver door. I checked all the connections and wires for the head unit and all looks good
