Thread: electrical issue
Showing results 1 to 6 of 6
    electrical issue
    so i bought a 2002 es 2.4l. first thing i noticed is when i open the door or flick the switch, the dome light doesnt come on. when i insert the key with the door open i dont get the dinging. if i have the headlights on and turn off the csr they shut off with the switch still on and the tail lights only work if the headlights are on but they dont respond when i press the brake pedal. all fuses and bulbs look good. already replaced the brake switch. also, the locks only work with the key in accesory
    Sent from my SM-J700T using Tapatalk
    drivers side seems fine. when i press the switch in and the key is in accesory the locks will lock. when i dont press it with the key in accesory the locks will auto unlock so im assuming the drivers switch works could it be another?
    i dont have the yellow thing on my fuse box. could that be a problem?
    im getting about 12.5 volts at brake light switch plug
