Thread: HVAC Shuts Off Randomly
Showing results 1 to 3 of 3
    Hello y’all. I recently changed the starter and battery on my 8G. Now I’ve run into a problem where I’ll have the AC running and then the fan will just stop and won’t come back on. Regardless of AC or Heat or fan speed it won’t turn back on. It’s intermittent. It might come back on the next day or it might not. However it is summer and I would like to keep my wife happy with some AC. Not sure if it’s the blower motor or anything else but I’m hoping some fellow Galant owners can help me narrow down the cause.
    Thanks in advance guys!
    New Member
    02-14-2017
    pottsgrove pa
    77
    I would start by checking to see if the wires and connections behind the climate control are clean and properly connected. Hope this helps
    Thank you. I tried to use it today and it didn’t work. I did remove the cigarette lighter panel to replug the connection so maybe I pulled something else while doing that. I’ll definitely check!
