Been planning this for a while since the drilled slotted setup I got degraded pretty quickly.
To complete the swap the calipers, brackets, new rotors, and pads for an 05 Endeavor XLS AWD were used.
The Rotors are quite larger and thicker, the calipers are dual piston instead of single.
Everything bolts right up, no modifications were needed, even the dust shields fit with the rotors. Did the test fit tonight got pictures when i figure out how to post them. Took it on a quick run, stops great, swapped back to paint them up, but will have final pictures once they are back on.
Clearance on the wheels is abut 3/8" but I do have the GTZ 16" Enkei Wheels, they would not fit under 15" wheels
