I've been searching but can't find a definitive answer. Could someone please tell me the diameter of the stock front sway bar on an 03 galant 2.4? I've read between 16 and 18mm. Also, does anyone know the size of the bushing brackets bolts? The bushings and brackets on mine look fine but the bolts and are nearly gone from rust. Im afraid if I even touch one of the bracket bolts it's going to shear right off. -_-
