Will a 6g F5M22 bolt up to a 7g for a 5 speed swap? I ask because I one sitting on the shelf and my slush box died so thing of doing another 5 speed swap. THe cases are different but for the most part the bolt pattern of the 6g clutch housing matches the bolt pattern of the 7g clutch housing.
I am probably just pissing up a rope here but the areas of concern are:
1. will a 7g clutch and pressure plate fit a 6g trans? I don't think it will but want to be sure.
2. will a 6g clutch and pressur plate bolt up to a 7g block. I am pretty sure the 7g has a 67 bolt crank and the 6g a 6 bolt crank so prettysure the answer is it won't work.
3. can a 7g clutch housing replace (bolt up to) a clutch housing from a 6g trans? I happen tol have a clutch housing from a 94GS (trans F5m31) from one that died.
