Thread: Heat/air selection messed up
Showing results 1 to 2 of 2
    Icon5 Heat/air selection messed up
    I have an '04 Galant with 137K. When I change the selector to move the air flow from defrost to dash to floor etc., it will never come out at the floor. My question is... is this a common enough issue that I need to start with an actuator, a blend door, the control unit or something else.
    I still haven't been able to figure out where to start on this issue... Any thoughts?
