Thread: Heat/air selection messed up
Showing results 1 to 4 of 4
    Icon5 Heat/air selection messed up
    I have an '04 Galant with 137K. When I change the selector to move the air flow from defrost to dash to floor etc., it will never come out at the floor. My question is... is this a common enough issue that I need to start with an actuator, a blend door, the control unit or something else.
    I still haven't been able to figure out where to start on this issue... Any thoughts?
    Just checking in again to see if someone has an idea on where I should start with this issue...
    open up the glove compartment trim and take a look if you can see the actuators move. If you are unable, you might have to try to remove the entire dash.
