Thread: Base Map 2.4L
Showing results 1 to 2 of 2
    Base Map 2.4L
    hello all be a long time from the last time i got to log on about my build. But i wanted to know if anyone here have a base map for the 2.4 dohc.
    08-18-2004
    Charlotte, NC
    1,022
    I use the Mitsu RVR as based when I switch over to a flashable ECM, the Fed Spec (00) Eclipse is a good starting place too.
    1994 GS FYI
    DSM/CSM Manuals
