2010 Galant 2.4l new alternator, & battery. 120a fuse on positive battery terminal checked good, 80a fuse in under hood fuse box checked good, all other fuses checked good. Battery terminals cleaned, grounds cleaned, iv'e went through everything i can think of without a charging system diagram to run through. Any other relays/fuses control the charging system? Does the ecu control the charging system? Help!!! Good to be back in a Galant.
