Thread: Using an Eclipse cat-back exhaust?
Showing results 1 to 6 of 6
    blakstarz73
    Is it possible to use the cat-back exhaust system for an Eclipse on a Galant? I figured since you can use most things from Eclipse on a Galant, I just wanted to know if any1 has tried using one. I saw a cat-back kit on Ptuning.
    Thanks
    it will work but you got to cut and chop it up since the galant is longer than the eclipse. IMO its not worth it unless u can't find the muffler universally just because, one of the reasons to have a cat back is to get the most power u can get from specific bends and for easy installation. cutting and chopping defeats both those purposes
    blakstarz73
    Ohh ok...... Actually, I already have a muffler and I really dont want to get rid of it, but if I can add on to it, that would be better. I have Bosal muffler so can I add on to that w/o gettin' a whole kit?
    Quote Originally Posted by blakstarz73
    indeedy. just get your local exhaust shop to bend u some new piping
    blakstarz73
    Thanks man.....about what size pipe would I need and also what type of catalyic conveter would be good to get or should I just stick with the stock one and just change the pipe?
    do a search...thats been discussed many a times
