Thread: Looking for info site!!
Showing results 1 to 7 of 7
    ConceptSleeper
    i was wondering if there happens to be a site that has the Mitu engines and their specs? Hopefully with the JDM engines as well!! on that note anyone have the specs on a JDM 4G63 DOHC Cyclone engine?
    escoson
    do a search on yahoo for jdm 4963 dohc cyclone specs, that should work because i get alot of results when i use yahoo and there always on point
    ConceptSleeper
    hmm, still no specs only dealers who sell em, but who dont list the specs
    New Member
    05-24-2003
    Cardiff by the Sea, SoCal USA
    55
    Re: Looking for info site!!
    Quote Originally Posted by ConceptSleeper
    JDM 4G63 2.0L DOHC Turbo with Dual Runner Intake Automatic
    1997cc
    TD04 13G turbo
    450cc Blue top injectors
    7.8:1 compression
    185 HP
    JDM 4G63 2.0L DOHC Turbo with Dual Runner Intake 5-spd
    1997cc
    TD05 14B turbo
    7.8:1 compression
    195 HP
    JDM 4G63 2.0L DOHC Turbo with Dual Runner Intake 5-spd (GVR-4 RS)
    1997cc
    TD05H 16G turbo
    510cc Yellow top injectors
    7.8:1 compression
    235 HP
    The Cyclone name also doesn't specifically refer to the dual runner intake manifold. The name has been seen on normal single runner intakes. It could just be a fancy name for turboed motors that Mitsu uses. They "Cyclone Motor" term is usually used to describe the JDM dual runner engine since it is the most common.
    Jason V.
    [b]<span style='color:red'>EVOL-ART / Evolution Artisan Tuning</span>
    If you want to fight the power, get the power to fight!
    <span style='color:blue'>C53A '89 Plymouth Colt GT Turbo 4G61T
    E38A '90 Mitsubishi Galant GSX 4G63T
    E39A '91 Mitsubishi Galant VR-4 1823/2000
    D27A '90 Eagle Talon TSi AWD 4G63T</span>
    ConceptSleeper
    ok well the n/a 4g63 is what i was refering too, and where did you get those numbers??
    New Member
    05-24-2003
    55
    I use to work for Mitsu. I mainly know turbos. I'm working on a Galant race car so I'm trying to get NT info. The differences between our motor and a JDM are always minimal. Maybe a 5 hp difference.
    Jason V.
    ConceptSleeper
    have you tried the clubdsm nt pages?
