Yes.
Can I put KYB GR-2 Shock with stock spring? Will it improve the handing?
If I put KYB GR-2 Shocks with stock springs, do they change the high of vehicle?
Yes, new struts will make for a nicer drive.
No, they are a direct replacement. They may raise it a bit if your stock struts are currently blown.
Aye like the KYB AGX adjustables...those will raise your car a little bit from an expected drop because the KYBs are longer than stock, but I wouldn't see your car being raised any higher on stock springs.
