Thread: OBD Code P0455 Manybrews, Please help!!!
Showing results 1 to 6 of 6
    Baltimore, MD
    2,848
    It came back again. I know my gas cap is tight, because I make sure everytime I fill up since the last time this damned code showed up. What can I look for in my Evaporative Emissions System to find a "Gross Leak". I'm out of warranty, (38k miles) so I'm pretty sure the dealer will charge me for whatever they do. Any help is appreciated. Good luck on buying your house, man. And Thanks.
    Chip
    Chip
    (Paint Code: Porsche LC9Z)
    most common failure is a faulty vent solenoid.
    pretty common, actually.
    nckid
    I had that code once, decided to look around my engine and found a vacum hose that had come loose. You could have the same problem.
    Baltimore, MD
    2,848
    Thanks guys. I checked the vacuum hoses and they all appear to be tight and in place. Where's the vent solenoid, maybe that will give me a clue as to where to look. I did replace my hoses with silicone ones, so it's possible i may have one loose or crimped or something. Thanks.
    Chip
    liquidsnow
    Probable Causes
    Loose Fuel Cap.
    Defective Fuel Cap Relief Valve, or incorrect relief pressure.
    Fuel overflow limiter valve failed.
    Purge line or vapor line is clogged.
    Fuel tank, purge or vapor line leaks.
    Purge Solenoid failed.
    Ventilation Solenoid Failed.
    Fuel Tank Differantial Pressure sensor Failed.
    Clogged or leaked Canister.
    Use of incorrect fuel
    Baltimore, MD
    2,848
    Thanks Liquidsnow. Can you give me an idea where to look? I don't have the Mitsu technical expertise to translate that list into English. Thanks to everyone for their help on this
    Chip
    Chip
