Thread: "all nos people"
Showing results 1 to 11 of 11
    island boy
    "all nos people"
    when is the best time to hit the juce at the track?
    Alister_McRae
    i heard its when you hit the top of your rpm's in third gear going into forth. But im not 100% sure, talk to Shane, he is our nos guy.
    b-boy_sky
    the best would probably be in 2nd gear above 3000 rpm no lower.....if you spray at the top of 3rd you'll already be across the 1320 mark....
    TWISTED II
    Quote Originally Posted by Alister_McRae
    if you hit 4th gear in a quarter mile, theres something wrong. start spraying in second gear. you should be done with the 1/4 by 3rd gear.
    09-22-2002
    Kissimmee, FL
    1,495
    Quote Originally Posted by ThaTwistedGTZ
    I dont have to use it until the top of my third gear because i have enough bottom end to push it all the way to fourth gear... Our second gear is our strongest gear we have the most trouble once we hit our third and fourth gear, because seemily thats where our power falls off, so that where i hit mine, becuase it has the most trouble and i have better times from there than hittin it from second.. Twisted you will probably run all the way to your fourth gear once your motor is back in, your bottom end will pull so much that you will have the need to use nitrous in third than anything else.. Even with my 5spd, i had the bottle on it, and i still have to use it in third because thats just how my car runs..
    thunderboy
    1990, JDM 4g63 DOHC n/a cyclone manifold (stock)
    normally how many shots you can put on this engine, using a wet system NOS, with stock external bosch fuel pump
    Alister_McRae
    Re: 1990, JDM 4g63 DOHC n/a cyclone manifold (stock)
    <div class='quotetop'>QUOTE(thunderboy)</div><div class='quotemain'>normally how many shots you can put on this engine, using a wet system NOS, with stock external bosch fuel pump</div>
    i dunno if that was a question or an answer to the question above. But if your asking how many shots you can put on our stock i4's, it is recommened at 50. 75 being the maximum.
    umm reading all the post on TGC,, i would recommend no NOS to Stock Fuel Pump,, but if you gone do it go for under 30 Shots of NOS,,
    if you do more,, u gone need,,
    Bigger Fuel Pump.
    Racing Type Fuel Injection,,
    and other Internal Engine,, Parts..
    if you dont believe me ask Twisted,, Shane,, and Some other mem how they blew up their Engine,, Specially Peter,,,,
    AkA K h O p A r I.
    I Am back BitcheZzZ
    thunderboy
    I bought a 2nd hand a cheater system (For V6's n V8's) then bought the flare jets for the system 40hp, 50hp and 60hp, I'm planning to install it soon but wanted to be on the safe side, aside from the electric external bosch fuel pump, currently I also have a B&M command flo FPR with gauge, A/F gauge and S-AFC, just need more info/advise thanks
    this the reply I got from holley:
    Date: Tue, 21 May 2002 17:13:04 +0800
    Subject: Re: flare jet sizes [T200205220048]
    References: <[email protected]> (added by techmail.holley.com)
    34/18 40HP
    37/22 50HP
    39/24 60HP
    41/26 70HP
    43/28 80HP
    46/30 100HP
    52/33 125HP
    61/38 150HP (max for 1 nozzle)
    Thanks, NOS tech dept.
    8ggalant
    does the 7g and 8g have the same fuel system...becuz i can name a 7g'er who's been sprayin fer well over a yr with no problem with no fuel upgrades...id like to kno cuz imthinkin about sprayin
    <div class='quotetop'>QUOTE(ThaTwistedGTZ)</div><div class='quotemain'><div class='quotetop'>QUOTE(Alister_McRae)</div><div class='quotemain'>i heard its when you hit the top of your rpm's in third gear going into forth. But im not 100% sure, talk to Shane, he is our nos guy.</div>
    if you hit 4th gear in a quarter mile, theres something wrong. start spraying in second gear. you should be done with the 1/4 by 3rd gear.</div>
    although i'm not using nos, i also have to shift to 4th gear by the end of the 1/4. my 2nd gear just spins, and 3rd gear pulls hard, but in 3rd gear, at 7000rpm i still have a bit of ways to go to the mark.. and i didn't think that 3rd gear could hit 106mph
