Thread: CF hood (vented) Group Buy going on right now...
Showing results 1 to 3 of 3
    PRE-EVO
    Just wanted to let you all know I have organized a CF hood (vented) GB that I posted in the GB forums. Be sure to check it out for updates and don't miss out now (though they will be available later also).
    Rich
    ConceptSleeper
    ok i checked it out and figured id ask some questions here to reduce un needed traffic on the GB thread, how long will they be available after the initial buy?? at that time will it be the vents that were originally decieded on from the GB?
    PRE-EVO
    It will be available for a good while afterwords. He told me the mold is good for a couple hundred hoods before needing to be re-done.
    Right now it looks like the Evo 8 vent will be the vent of choice as all but 3-4 have chosen that vent. If there was 10 for each then I would try and see if both could be done.
    Rich
