Shouldn't Kamikazee or wherever the headers came from have answers to all these questions? Try emailing BigJosh.
Chip
Grettings again.
The hi flow cat i got with my header, has an air input tube. Neither of the stock cat's had one. DO I need to supply this cat with air for it to function properly, and if so - where am I going to get it from, or can I just cap it????
Chip
Chip
(Paint Code: Porsche LC9Z)
Are you sure that you are not talking about a bung for the O2 Sensor? If you have a fed spec, you may need to cap the extra bung holes b/c it's for the extra O2 sensor for a Calif. spec car.Originally Posted by cdaw2001ES
Like Chip suggests, you should email your distributor to be sure.
Nope - definatley not a bung. It's allready capped, so I'll just leave it
