Thread: Your Suspension Setup
Page 10 of 14 FirstFirst ... 67891011121314 LastLast
Showing results 181 to 200 of 280
  1. #181
    Used to have:
    TEIN super street dampers with pillowball upper mounts
    INGALLS camber kit in the rear
    3G Eclipse OEM front strut tower bar
    D3 DESIGN chassis stiffening kit
    Addco rear sway bar
    225/40 18 Yokohama Parada spec 2 tires
    Now I have the same as above except:
    I just recently swapped out my Teins for H&R springs with KYB AGX shocks/struts all around. My rear Tein dampers were blown out and one of the front pillowball upper mounts appears to have some play in it. I have the AGX's set to 2 in the front and 4 in the rear. I'm actually very surprised at how much smoother the ride is and yet the handling is still really nice. I also have Sumitomo HTR Z III tires now. As much as I loved how well my Yokohama Parada spec 2's gripped the road, the Sumitomo's grip very well and at the same time have less road noise and are much more comfortable. Both tires are pretty good in the rain.
    With the H&R springs, I wish the front dropped just a slight bit more, but I can deal with the slight fender gap considering how comfortable the ride is now.
  2. #182
    02-07-2007
    ORLANDO
    1,599
    My Setup
    2002 4cyl ES
    GR-2's
    Stock Springs
    3G Strut Bar
    Addco Sway Bar
    02-03 16' gtz wheels
    Michelin Hydroedges
    Its stock ride but the Sway Bar made a hell of a difference with control and body roll if your staying stock like me I highly recommend it
  3. #183
    updated:
    tein basic coilovers - riding 1 finger gap all around
    negative camber on rear tires. zero camber on front
    18" g-games 77w by rays, 7.5" wide, +42 offset, 19 pds, gunmetal color
    225/40/18 falken ziex512
    dc sports strut bar
    suspension techniques rear sway bar
    rolled rear fenders
    i scrape on almost everything now. and im not talking about my front bumper. i have to take driveways and dips slower. hard to drive slow when my suspension allows me to fly around turns without needing to even think about putting my foot over the brake.
    how many inches is your drop?
  4. #184
    AGX @ 3 all around
    Eibach Pro Kit
    ST Rear Sway Bar
    DC Strut Tower Bar
    Ingalls camber kit
    -1 camber all around
    Evolution 9 wheels
    235/45/17 Yokohoma Advan AO46
  5. #185
    Just wonderin I want to go with the kyb agx's but the site only shows gr-2 series for the Galant. those who have them what agx's are you useing? oh an i have a 2002 i4 es.
  6. #186
    09-25-2006
    Central, Cali
    1,145
    o3 eclipse agx fit our cars same specs
    03 I4
  7. #187
    Thanx
  8. #188
    Quote Originally Posted by greddy View Post
    AGX @ 3 all around
    Eibach Pro Kit
    ST Rear Sway Bar
    DC Strut Tower Bar
    Ingalls camber kit
    Evolution 9 wheels
    Everything is the same except now I have megan coilovers instead of the AGX and pro kit.
  9. #189
    Gbaby2089
    bags are not low! you can adjust you don't have to live with the consequences of lowness...
  10. #190
    08-13-2008
    Waterbury, CT
    3,331
    i just installed my tokico illuminas and tokico springs today.. 1.5 drop all around and the rear is set on 4 and the front on 4 as well. i am very happy with this setup as roads around here suck and i only bottomed out 2 times all day and it wasnt even that bad
    2014 Lancer Evo GSR
    1996 Galant S 5 Speed Turbo
  11. #191
    01-08-2008
    Levittown NY
    2,786
    Being done Saturday:
    03 Galant Es if you couldn't tell...
    Struts/shocks: GR-2s all around
    Springs: Tein S-Tech 4cyl
    Wheels: 18x7.5 came with car from auction.
    Tires: 215/40/18 Falken 512s
    Dont know if I need a camber kit yet.
  12. #192
    10-24-2003
    1,432
    Alright, changed my alignment up to where it is so responsive and crisp its impossible to describe.
    On 245/40/17 Hankook Ventus RS-2's with 17 x 8.5 front and 17 x 8 rears
    JIC magic coilovers
    ST rear swaybar
    Full energy suspensions kit
    Front alignment -1.5* camber +.4* toe out, 2.7* caster right 2.4* caster left
    Rear alignment -.8* camber -.23* toe in, obviously 0* thrust angle
    The car is so nuetral its not even funny, turn in and initial bite are phenominal and the car just stays stuck through the entire corner.
    www.gooichimotorsports.com
  13. #193
    I got a 1995 galant s, max speed coilover, kyb gr2 struts, 16" ADR wheels, and 50 series tires.
    The ride isnt to bad. tight on corners, but bouncy due to blown struts in rear.
    I had a buddy with a 94 gs. he had eibach sport springs and koni struts. with 17" enkei wheels. That car rode like a dream. to bad koni struts are so damn expensive. I would deffinately recomend that setup.
  14. #194
    TGC Regular starh4x's Avatar
    11-30-2008
    New Zealand. HTOWN
    527
    Apexi world sport coils
  15. #195
    03-12-2007
    Dallas TEXAS
    2,041
    Quote Originally Posted by starh4x View Post
    still waitin on them pics
  16. #196
    Icon14
    I wanting to see as well...
    Kid
    Saving People, Property, And The Environment From Such Dangers As Fire, Hazardous Materials, And The Grim Reaperâ„¢...
  17. #197
    02-07-2007
    ORLANDO
    1,599
    Quote Originally Posted by 02redgalant View Post
    2002 4cyl ES
    GR-2's
    Stock Springs
    3G Strut Bar
    Addco Sway Bar
    Michelin Hydroedges
    Gr-2's
    Galant Eibach Pro Kit
    Ebay Rear Camber Shim Kit
    3g Strut Bar
    Front Energy Suspensions poly bushings
    Rmr 24mm Rear Sway Bar
    Evo 7 Mesh Wheels 17x8
    Eagle Gt 225/45/17
    Handles Nicely,poly bushings for the front were night and day for me,Ride's a bit ruff I blame the tires tho...Corrected rear camber to -1.3 for both sides although the pro kit doesnt bring camber out of spec
  18. #198
    blue8g
    GR-2
    Tein S-Tech
    G-Games 18x7.5
    Kumho Ecsta ASX (well worn) 235/40/18
    handles worlds better than stock.....but it's still nothing outrageous.......3g strut bar coming soon
  19. #199
    gr-2
    teins s tech
    17 wheels
    215/45/17 hancook v4
    strut bar
    i know a guy that saw a guy that knew a guy that once passed by a car that had been painted. Ill ask him tomorrow after consulting my magic ball to determine WHERE YOU LIVE in proximity to a paint shop NEAR WHERE YOU LIVE..................
  20. #200
    10-18-2007
    Glen Burnie, MD
    1,314
    Megan racing coliovers.
    DC sports STB
    Megan racing rear underbrace
    Hankook ventus rs-2's
    Brembos :D
