Thread: Your Suspension Setup
Page 5 of 14 FirstFirst 123456789 ... LastLast
Showing results 81 to 100 of 280
  1. #81
    2003 ES I4
    Springs: Eibach Prokit
    Shocks/Struts: KYB GR-2
    Wheels: Kazera KZ-R 16x7
    Tires 205/55/WR16 Kumho ECSTA Supra 712
    3rd Gen. Eclipse OEM Strut Tower Bar
    2003 Dover White Mitsubishi Galant ES
    1997 Tarmac Black Mitsubishi Eclipse GST
  2. #82
    Fort Worth, TX
    1,418
    2000 V6 ES
    Springs Eibach prokit
    shock struts KYB AGX Settings 3/front and 2/rear
    Wheels: 16 stock (winter)
    18x7 (summer)
    Tires 16 regular stock size
    18 225-40-18 - Kumho
    After lowering the car my ride is almost identical whether i am on 18 or 16, the only different is when hitting a bump you do feel it a little more but thats due to less rubber.
  3. #83
    12-17-2002
    Sherman Oaks, California
    4,304
    updated:
    17x7 wheels
    225/40/17 tires in front
    215/40/17 tires in rear
    KYB AGX struts
    Eibach ProKit springs
    18mm rear sway bar w/ poly bushings
    rear camber kit
    front adjustable camber kit
    poly upper strut mounts
    just got an alignment this week...
    my shit pwns
    http://socallifestyle.com/
    1994 Galant GS 5spd
  4. #84
    1995 Galant
    struts: Gab Super Street
    springs: Eibach Sportline
    wheels: 5Zigen 5ZR (18x7.5)
    tires: Falken ZIEX 512 (215/35/18)
    ps: all to be sold by spring/summer
  5. #85
    11-24-2002
    Originally TGCNY, Now TGCTX
    1,781
    MY INITIAL SET UP
    1999 Galant ES
    Springs - Tien S-Tech Sports Springs (3G Eclipse GS Application)
    Supposed to be
    1.8 front (actual was about 2")
    1.2 Rear (actual was about 1.3")
    Struts - KYB GR2 (3G Eclipse GS Application)
    Shocks - KYB GR2
    Rims - 2003 GTZ 16" rims
    Tires - Generic
    Ride was actually pretty good.
    But had to replace the Eclipse struts after about a year and a half. I would recommend just putting the extra money in for the galant parts if you have them.
    Didn't Rub
    Didn't have to roll Fenders
    Topped out veeeeeery rarely.
    MY CURRENT SET UP
    1999 Galant ES
    Supposed to be
    Struts - KYB GR2
    Shocks - KYB AGX (set to 2)
    Rims - 18" Alero Dyno Stars
    Tires - Falken 225/40/18ZR
    Strut Bar - Freedom Design
    Camber - Home Depot Camber Kit - 4 washers per bolt.
    Ride quality decreased with the new rims.
    It's noticibly on turns stiffer with Strut bar. (not sure i like it)
    Camber was not needed intially, became very noticible later.
    Low Profiles tires did not rub.
    Had to roll fenders.
    Top out veeeery rarely.
    Overall
    Very agressive drop...i love how it looks.
    -Pedro
  6. #86
    <div class='quotetop'>QUOTE(Galant95)</div><div class='quotemain'>1995 Galant
    ps: all to be sold by spring/summer</div>
    You got the sportlines on, how low is the drop?
    Signature wanted call: 1800-Darkkend
    <a>Take Better Photoshots Tips from the Pro's</a>
  7. #87
    just finished mine:
    2003 ES
    17 Konig Imagines Opal finish
    225/45 Ziex 512 Falkens
    1.8" drop on Sprint springs
    AGX's front and back. 4 position adjustables
    "If Wal-Mart is lowering prices everyday, how come nothing is free yet"
  8. #88
    Member
    10-31-2005
    Prairie Village, KS
    141
    Re: Your Suspension Setup
    2003 Galant ES i4
    Springs - Tein S-Tech
    Shocks and struts - KYB GR-2
    Camber kit - not needed
    Rims - Factory 16" alloy wheels
    Tires - Goodyear Assurance Comfortred 205/55/16 all season radials
    Definitely firmer and harsher ride with this setup, but body roll is significantly reduced. Handling is greatly improved. The car also looks much better without the huge wheel well gap. It dropped more than the Tein specification. I'd say about 2" in front and 1.7" behind.
  9. #89
    abbadon01
    1995 2.4 ES 4G64
    Sprint Performance Sport Spings
    KYB AGX Struts all the way around(all 4 struts were blown anyways)
    KYB Strut Mounts
    Progressive Camber Kit
    Stock Wheels and rims for now till after the wedding
    no STB yet either/however there is one by Stillen that i think will fit.
    the Sprint springs took me by suprise. Definately worth looking into. especially if you are running on limited cash flow. the drop was a modest one (1.5-1.8)and the ride quality is really good. corners wonderfully. I am sure it will do much better with polyurithane bushings and a rear sway.
  10. #90
    2001 GTZ
    Struts and shocks: KYB AGX
    Springs: Tein S-Tech
    Camber kit: RRE rear spacers
    Rims: 16" stock GTZ alloy wheels
    Tires: Falken Azenis ST115 205/55/R16
    STB: 3G Eclipse
    Swaybar: ADDCO 22mm with SS endlinks
    AGX is set to 3 all around, started on 4 but then I had to listen to my wife
    Whoever said it's love all over again... Now I know what he was talking about. Car takes corners like a champ, no more swingibingi while accelerating or hard braking, changing lanes is a 100% pleasure. And it looks awesome (ca 2" front 1.8" back), I love it!!!
    update: Addco swaybar FTW! Honestly, I didn't expect a lot since the stock was 19 already, but I have to say, even that 3mm does make a difference
  11. #91
    **UPDATED**
    94 galant GS w/ 4g63t
    -Kyb AGX all around w/ energy poly upper mounts
    -eibach pro kit
    -complete energy suspension polyurethane bushing kit installed
    -Forza front strut upper bar
    -obx rear lower strut brace
    -front and rear ignalls camber kit.
    -Konig Prophet 18" wheels on 225 40 18" nitto tires
    -2g FWD RMDSM swaybars front and rear with poly bushings
    -True JDM ralliart all aluminum 4 point front lower brace
    anodize red
    http://i20.photobucket.com/albums/b240/doh...thegoods004.jpg
    http://i20.photobucket.com/albums/b240/doh...thegoods002.jpg
    http://i20.photobucket.com/albums/b240/doh...thegoods005.jpg
    http://i20.photobucket.com/albums/b240/doh...thegoods006.jpg
    Weight loss
    -complete a/c system delete
    -battery relocate to the trunk
    - cruise control system delete( non cruise throttle cable added)
    -spare tire & jack delete (added AAA autoclub card to the center console)
  12. #92
    01-24-2005
    DFW/Stillwater
    2,752
    Springs:Tein S.Tech
    Shocks: F/ stock R/ KYB GR-2
    Wheels: Force GR-5 18x7.5 (45mm offset)
    Tires: Hankook K106 225/40/18
    Near Future: 3G Eclipse Strut Bar.
    is there any drilling of the firewall involved with the installation of this part?
  13. #93
    Quote Originally Posted by lonestar22
    Springs:Tein S.Tech
    No. The brackets that would mount to the Eclipse's firewall will not mount to the Galant's firewall on the account that the Eclipse's engine bay is about 2-3 inches shorter. The brackets on my bar just sit there, it isnt really noticeable. I thought about using a dremel to take them off, but im too lazy to mess with it.
  14. #94
    phizz2k
    Springs: Ground Control Coilovers
    Shocks: KYB GR-2 all around
    Tires: Kumho Ecsta 712 zr18
    Near future: front upper strut bar and rear lower bar.
    The ride was stiff in the begining but has balanced off nicely now. I would recomend them, if you could get them at a good price...
  15. #95
    11-24-2002
    1,781
    Quote Originally Posted by Darkkend
    Quote Originally Posted by Galant95
    1995 Galant
    Quote Originally Posted by proteusx301
    Springs:Tein S.Tech
    Allan do your thing...
    -Pedro
  16. #96
    LOL Necromancy
    Quote Originally Posted by Kalamidad
    1995 Galant
    Posted: Tue Jan 17, 2006 2:46 pm
    Springs:Tein S.Tech
    Posted: Wed Apr 26, 2006 12:51 pm
    And please explain to me how those post are off topic? cause I dont know how me asking John if he installed MY SUSPENSION PARTS is off topic in a thread called "Your Suspension Setup"?
    Or a question about some ones SUSPENSION SETUP and being answered is offtopic?
    Also your is and also
  17. #97
    18" Arceo Dynostar
    KYB AGX Adjustable Gas Shocks
    TEIN S.Tech Lowering Springs
  18. #98
    2001 GTZ, new setup:
    Rims: 17x7 Enkei EVO V
    Tires: BF Goodrich G-Force Sport 225/45/R17
    STB: 3G Eclipse
    Swaybar: ADDCO 22mm with SS endlinks and PU bushings
    this+solid motormounts=I love to drive more and more...
  19. #99
    12-17-2002
    4,304
    <div class='quotetop'>QUOTE(peanotation)</div><div class='quotemain'>updated:
    17x7 wheels
    KYB AGX struts
    rear camber kit
    my shit pwns</div>
    update: full prothane polyerethane bushing kit installed all throughout car.
    1994 Galant GS 5spd
  20. #100
    2003 ES, i4
    tein s-tech, stock shocks
    no camber kit neded
    18" g games 77w by rays, 7.5" wide, +42 offset, 19 pds, gunmetal color
    225/40/18 falken ziex512. compared to similar tires i had, falkens are thinner dispite their width rating. the 225 are more like 215 and the 215 are like 205
    dc sports strut bar, no rolled fenders
    stock struts on tein springs are holding up pretty nice dispite driving on nyc streets for 6 months so far. wish my front end could be 1/2"-1" lower. tho i scrape on 10% of driveways already
    updated:
    tein basic coilovers - riding 1 finger gap all around
    negative camber on rear tires. zero camber on front
    18" g-games 77w by rays, 7.5" wide, +42 offset, 19 pds, gunmetal color
    dc sports strut bar
    suspension techniques rear sway bar
    rolled rear fenders
    i scrape on almost everything now. and im not talking about my front bumper. i have to take driveways and dips slower. hard to drive slow when my suspension allows me to fly around turns without needing to even think about putting my foot over the brake.
